Hi,
get the following msg each time i tryto convert my avi´s captured with my pinnacle card and the pctv tool for it:
Frame Rate 10000000/383495 is not support. Support Frame Rate are 23.967, 24, 25, .....
anyone knows whats happening ?
Tmpgenc does the job, but the produced file is very slow, about 12 Frames..
Thx for any help,,..
diSer
Frame rate of your capture is illegal in CCE. You need to change it to one of legal frame rates in CCE. Since you mentioned TMPG, let's start from there:
Save your project in TMPG. Use VFAPI to convert TPR file into a fake AVI.
Drop this AVI into CCE. There you go......
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
Gamebridge--Capture Card Problems
By Magma999 in forum Capturing and VCRReplies: 3Last Post: 25th Apr 2009, 14:23 -
Problems transferring resized photo's to sd card
By RKelly in forum ComputerReplies: 2Last Post: 19th Dec 2008, 19:34 -
Framerate Problems
By InvincibilityCloak in forum Video ConversionReplies: 1Last Post: 26th Mar 2008, 16:17
