I'm using the Pioneer DVR-104 and having some problems erasing Whitelabel DVD-RW's. Princo V1.1 work fine (everytime) with Nero 5.5.9.9 but the Whitelabels only do it occasionally. Most of the time I get "Erasing Failure".
Anyone know if these discs are problematic?
I'm having the same problem with my "EZSTOR" brand DVD-RW, no problem with my Sony DVD-RW. Low cost always means low quality.
I've successfully used the pioneer DVDRW that came with the burner.
I have had trouble with the "optodisc" brand, Thinking they should be called "optoshit".
Some "verbatims" are on the way.
I have not had trouble with DVDR media. 1 coaster in about 50 burns, two different batches.
Jim
Problem erasing a Verbatim DVD+RW
By nadizo in forum DVD RippingReplies: 10Last Post: 2nd Mar 2009, 07:56 -
Need help with odd problem with erasing/recording DVD+RW
By fdm2000 in forum ComputerReplies: 17Last Post: 3rd Nov 2008, 18:02 -
Help with odd problem recording/erasing DVD+RWs
By fdm2000 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2008, 08:24 -
Erasing Hardrive?
By ReadB4Assembly in forum ComputerReplies: 2Last Post: 14th Mar 2008, 17:34 -
For erasing a RW disc, is a DVD drive specific ?
By coody in forum DVD RippingReplies: 5Last Post: 11th Oct 2007, 09:40
