YUY2: is this 24-Bit color?
I am capping with a Pinnacle PCTV and am unable to cap with RGB-24, so instead I figured that RGB-16 would be the next best thing. Until someone here on the board pointed out that RGB-16 is of low quality I was convinced it was better than YUY2.
So what format should I cap in to achieve the highest quality compared to my original source? My source is mainly DSS and the occasional cap from laser disc. I highly doubt I will ever waste my time trying to cap from VHS.
Thanks for any help!
YUY2 (and YUNV and V422)
YUY2 is another in the family of YUV 4:2:2 formats and appears to be used by all the same codecs as UYVY.
Horizontal Vertical
Y Sample Period 1 1
V Sample Period 2 1
U Sample Period 2 1
Effective bits per pixel : 16
Positive biHeight implies top-down image (top line first)
There is a help page here which contains information on playing AVIs which include video stored in YUY2 format.
This is from http://www.fourcc.org/ -
Visually 16 but YUY2 is leaps and bounds better than 16bit RGB for capturing video.
To quote some authority on this matter:
"Which capture format should I choose if I'm going to use video compression?
Ultimately, you will need to choose a format which is compatible with the codec, but if you have a choice, always choose YUY2, UYVY, or YVYU over RGB24. Here's why:
TV cards generally use one of two chips, either the Zoran ZR36120 (FlyVideo-derived devices), or the Brooktree/Conexant BT8x8 series (everyone else). If you look at the datasheets for these chips you will find that they either accept YUV 4:2:2 data from the decoder or produce it internally. Guess how they produce RGB24 data when you ask for it? You guessed it, the YUV 4:2:2 data is upsampled to RGB24. This means that the extra color resolution that RGB24 gives is entirely fabricated.
Choosing YUY2/UYVY/YVYU over RGB24 typically gives you a sizable speed increase, and gives you better compression with Huffyuv.
RGB16 introduces horrible banding and signal loss, while RGB32 just adds an extra 8-bits of junk to RGB24. There is no point in using either."
(Avery Lee, author of VirtualDub)
Lossy 32 bpp (32-bit color) codecs
By videohelperee in forum Video ConversionReplies: 9Last Post: 12th Dec 2011, 22:13 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
8-bit color RGB versus 10-bit color 4:2:2
By fouronthefloor in forum Capturing and VCRReplies: 4Last Post: 9th Oct 2010, 07:20 -
Xvid 8 bit color depth resoultion problem
By afcoff in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 00:50 -
Calibration of an 8 bit digital component editing system using color bar.
By edDV in forum Video ConversionReplies: 4Last Post: 20th Feb 2008, 13:48
