  1. Is there a utility out there that can tell you what format your mpeg file is...mpeg-1, mpeg-2 & so on? I've tried Bitrate Viewer, but it doesn't seem to work very well.
    Thanks for your help,
    Bill
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    unless you are using the main concept codec which doesnt tell you anything - just check properties in media player and it will show you bit rate and frame rate and mpeg type .. (works with ligos and nanopeg and some other codecs)
    there are also some other various apps which dont recall - i use snell and wilcox and m-probe applications which tell you more than you would ever what to know ..
