I was hoping someone might know what "read beyond end of file" means at the end of dvd2svcd? Does it mean I am finished and if so what is my next step? I have Nero as my burning software and i also have the mpge 2 plug in. Any help here would get me closer to finally making a svcd. Thank You, WILL
When I use DVD2SVCD I usually check the box that says Auto Shutdown (under the conversion tab), and then when I get up in a morning (leave my PC overnight processing), I turn it on to find the Bin & Cue files in the DVD2SVD/Movies folder and then burn them with VCDEasy !
Panther
All say Grrrrrrrrrr...................... -
Ok Sir are you saying I must click on "auto shutdown" to get my bin & cue files? I have looked in vain for these Bin & Cue files even did a search they don't exist on my pc. In the folder you mention i do have the vob files and other misc. file but nothing saying cue/bin. I think I am going to go crazy soon. I do appreciate the answer. I will try the auto shut down feature, but i don't see how that will work. Thanks Will
OK thanks. But there is no cue/bin files in my vcd imager folder? maybe it is time to give up on making a svcd. thanks , Will
Svcd2dvd
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Apr 2010, 05:55 -
SVCD2DVD and i7
By ttyke32 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th Mar 2009, 15:01 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Feb 2009, 14:58 -
svcd2dvd
By tempac in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2008, 22:43 -
Question re updating to latest version svcd2dvd
By Lord Flange in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 11th Oct 2007, 19:04
