Folks,
I designed a project in DVDIt which plays fine when tested on screen. However when I goto burn it I get the following error: Build Failed: Pic before sequence end (dvderr - 26303).
From reading various post here it seems the header is not correct on these files. What can I do to correct the header on the mpgs I have?
Thank you for your time and help.
Z
-26303 Pic Before Sequence End usually denotes an unexpected end of file, possibly due to corrupt or incomplete MPEG file. If the MPEG file was edited or truncated by another application it may not have done it correctly. You should recreate that file and import it again.
Ok just got off Sonics site and picked this up. So I can not recreate the file is there a program that will scan the mpg and fix?
Critical Error (Event ID 41 Kernel-Power) causing win7 BSOD & reboots
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 28th Mar 2012, 16:19 -
mkvmerge: MPG -> MKV causing double the framerate?
By KeyMs92 in forum Video ConversionReplies: 9Last Post: 8th Oct 2011, 17:13 -
ıs Xvid 1.2.2 causing undersized files in AutoGK?
By Anonymous5394 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2010, 06:19 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 01:51 -
Error burning .mpg files to DL disk
By Anonymous4374945 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
