I use TMPGEnc to create DVD quality MPEGs and burn these to a regular VCD - sure the file size will limit the length, but I would get the quality I am after - Works well for PC playback.
What I need to know is will it work in a VCD/SVCD/XSVCD compat DVD player such as Panasonic DVR20 ?
It is called mini-DVDs. Click on the "DVD Players" on the left and search for yours and see if it plays mini-DVDs.
Firstly, these are NOT miniDVDs. A miniDVD is burning a DVD type image onto CD-R media. Very few players support this.
What you are making is a high bitrate XVCD.
BTW, an "XVCD compatible" player is an oxymoron. XVCD = non-standard/compliant VCD. You will always be able to make an XVCD that won't play on a particular player.
Most DVD players can play VCDs with bitrates higher than the standard. How high you can go will depend on your particular player.
Regards.Michael Tam
w: Morsels of Evidence -
Ah, sorry. Missed the part that he mentioned his file was burn onto a VCD. My mistake. Anyhow, check the DVD Players Compatibility list and see what others talk about the XVCD on their DVR20. Obviously, YMMV.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52
