Can anyone help me with my problem? I had no suggestions which have been of use. TMPGEnc has suddenley stopped being able to convert to SVCD, whenever I set it up to do so I get the wrong aspect ratio and in normal VCD resolution. Everytime I look in settings/advanced the resolution in the greyed out box it shows 320 x 240 so it seems to have locked out SVCD. I downloaded a codec called the mpeg2 codec which is supposed to allow TMPGEnc to do this conversion but it has not cleared the problem. Until I downloaded this though Windows Media Player was saying Error Downloading Codec everytime I tried to open the converted files. I don't understand this as when I started converting this film and did the first part it was fine then suddenley for the 2nd and 3rd parts I got a jerky framerate and low resolution. Installing the codec cleared the frame rate problem but nothing else. This is driving me mad as it should be easily solved but no one has an answer. I have also downloaded and installed Nimo Codec Pack as advised and this did no good either. Hellllp!!!
reinstall the template ... looks like you saved over it ..
just download tmpgenc again use the supplied templates -
What is your TMPEGEnc version? If it's a Plus version, did you do the right thing to get rid of limitaion. Just for a thought thou, I'm not sure becuz I'm already done(crack) mine.
PS. Can I say crack, admin? -
No no no. Any sensible suggestions? I have already re-downloaded the prog, and tried those templates. I have tried it on different drives as well. That was the first thing I tried!
Originally Posted by crowby
responding in your manner will not garner much empathy to your plight - or likewise most likely further help.
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11
