Hello everybody,
I began trying to convert a divx avi to mpeg using tmpgenc and got all kinds of problems with that. So next i'm trying to use virtualdub to capture the audio. But here's my problem. When i use the full processing mode i get a parameter error. Does anybody know what is causing this and how to fix this. Or maybe another program to use to extract the audio.
thanks,
eric
If you just wan't to get the audio as it's stored in the DivX you can leave audio on "direct stream copy" and "Avi audio" and select "Save Wav" under file. Make sure you enter a filename ending with .mp3. Otherwise it's possible that some programs interpret the audio file incorrectly.
Regards,
Willem -
If you're only attempting to capture the AUDIO only, there are various ways.
-Method #1-
Use TMPGEnc, select the video as Input for Audio. Choose Audio Only option. That will result in an MP2 audio file. If you need to make it into a WAV file, use Winamp to decode the MP2 file to WAV.
-Method #2-
Use SoundForge to open up the video and choose the Save As option and export it as a WAV file (or any other supported format).
-Method #3-
Use VirtualDub to extract the audio portion as stated on the previous post above...
Good luck.
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
FAVC errors
By thai1 in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2008, 13:39 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
