Hi All,
Have a question, hope somewould would take the time to respond.
I've been trying to export a movie (.MOV) from Quicktime Pro 6 using 'Export to Toast Video CD'. It's the proper length to fit on a disk. Whenever it starts exporting, I soon get a message - "Couldn't export the movie because the compressor could not perform a needed operation".
a) What does this message mean?
b) How can I change compressors? I couldn't find this option on Quicktime.
The options I use are standard default settings. Format: NTSC (29.97); Image: Fit; Mode: Normal.
Thanks for your help in advance.
Results 1 to 1 of 1
QuickTime Pro exporting image sequence with the frames in the wrong order?
By adam-tl in forum Video ConversionReplies: 2Last Post: 29th Nov 2011, 15:55 -
Final Cut Pro, gives me GENERAL ERROR when exporting to Quicktime
By Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 14:26 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
Quicktime Problem: Playing and Exporting
By hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2008, 15:48 -
Problem exporting AVI to H.264 in Quicktime Pro
By newsclips in forum Video ConversionReplies: 2Last Post: 31st May 2007, 00:46
