I was wondering what the most reliable way to make an exact copy of a SVCD that is stored on a CD-RW. I cant use COPY disc with both my cd-rom and cd-rw drives coz my cd-rom doesnt accept cd-rw disks. I was thinking that I make an image of the CD-RW then burn it. (I cant choose between nero, disc juggler, ez cd creator and clone). any suggestions? thanks
make a image and burn it .. nero works fine for this ...
you could also just copy the files from one drive to the other as your cd will read much faster than write .. though for some sytems you may want to turn the speed down on write if on same ide channel .. -
I 2nd that. I been using clone-CD for 2 1/2 years and find it an Xellent program. Use it for true 1:1 just remember to do the copy and burn both no higher then 4x or 8x as this should produce the best copy.
Computers
