I have a bunch of clips in DV Type 1 format from my Sony Digital 8. I have used TMPEGenc without issue, but to use CCE 2.64, I have to convert the DV to Huffyuv before it will encode. Why can't CCE deal with DV straight away? Also, how do I check if I even have DV codec loaded on my system? Every time I try and play a DV file with WMP, it says the codec is not available, but then it plays the file anyways after I click OK.
Also, VirtualDub gives me an error too, when I try and load DV file as well. It gives me a format error, so I suspect it may be a simple codec issue.
thanks.
I got a reply over in the DVDplusRW forums. I needed to simply load Main Concepts demo DV codec. It worked like a charm. Didn't solve some other issues I have with other apps, but that is ok.
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 09:20 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16
