hi guys, i have a few questions, maybe one can help me with some of these questions!?
1.with which program can i add another soundstream into a svcd???
2.nandub does not work, does virtualdub fit my needs???
3.how do i choose the other soundstream when watching the movie with windvd???
4.does the svcd still fit on a 700mb CD-R when having added the other stream???
thx 4 da help
-sky-
1) You can use TMPGenc or bbmpeg. Simply author all streams separately and multiplex them together into one mpg. In TMPGenc use the multiplex option in mpeg tools, not simple multiplex. In bbmpeg there is an option to add an extra audio stream. Just look in the EDIT section to find out how to multiplex with these programs, and isn't dual audio tracks in a svcd convered in the svcd guides?
2) Nandub and Virtualdub are not really even used for svcds. No they will not work you need an mpeg multiplexor.
3) To switch between audio tracks in winDVD right click on the screen and go to Audio. Here you can toggle between audio channels. From my personal experience this only works with a burnt svcd, not just the mpg. With STHvcd I can switch between audio tracks on the mpg though.
When played on a hardware dvd player you use the audio button to toggle audio channels.
4) An 80 min/700MB cdr holds 800MB's worth of data when burnt in mode 2 which is what vcds and svcds use. Whether you have 1 or 2 streams is irrellavant, all that matters is that the total size of your mpg and any additional overhead (authoring overhead, menu's, segments, etc...) does not exceed 800MB's.
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
