I have split a avi file in v dub into two parts and the below happens
on computer vcd through power dvd plays fine and in sync
on dvd about a sec out which is quite noticable
the vid and audio that is
can anyone suggest why is it in ther burning process cos they were burned at 4x to avoid errors
any one out there know the answer?????????
I had similar problems before. I saw in some discussions to try burning at lower speed (atleast half the max rate supported by your cd-burner)
It worked for me. I dont know how!!!
may be the reading mechanism used in a computer drive and standalone players are different and depends on quality of written data.--
DV-CAM; PCMCIA-FireWireCard; 600MHz PIII;
80Gig 7200RMP FireWire HardDrive-External -
i am not burning faster than 4X so i dont think its that and ther disc quality is acceptable
Checkout this webpage -- this is about audio cd's made on CD-Rs
at different speeds..
http://www.cdfreaks.com/document.php3?Doc=73
I usually burn my VCDs at 4x on my CD-Rs and 2x if it is a CD-RW
If I burn at 4x on CD-RW, sometimes I get noise in the video when it is
played on my dvd player, but plays fine on computer!--
I burn my vcd's at 12x and they play just fine on my standalone player.
A few questions: what prog do you use to convert avi to vcd? And also, when do you cut your movie? Do you cut it before converting, while converting using a source range, or after it is converted? -
i use nero 5.9 to encode then burn at 4x and i cut before but some are already pre cut
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
Cant read DVD on computer....but can on player!!
By DrRaven in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2009, 04:02 -
Subs sync ok on computer but off in player !
By dexterdoo in forum SubtitleReplies: 1Last Post: 15th Jan 2008, 14:05 -
VCD audio out of sync on player
By burnerbie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 10th Aug 2007, 12:15
