    Mar 2001
    Niceville
    Is is it best to leave it at default or play with the settings (color, contrast, brightness, tint)? It seems better if the settings are more bright than dark b/c the pixels are more evident. My captures have varied. I sometimes have to blow the picture up on the monitor in order to change the settings b/c it's hard to tell in a little 3 inch box.
  2. I'll be happy to give you those if you can tell me, PRECISELY, EXACTLY how much ketchup you like on your french fries, and then GUARANTEE that I will like that amount, as well.
    Variations in PC display, TV, source, many others, and personal preference make your question impossible to answer. A generic answer would be to either leave at default or kick the color up slightly, then test on your chosen viewing equipment, adjust to taste - kinda like the ketchup.
