is it possible to join 2 avi files with different sampling rates. i downloaded the dvd rip of spiderman and both avi files have slight differences in the sample rate. i was trying to join them using virtuadub
cheers
You can use AviSynth to have VDub join the videos. Interested?
Hello. -
sure am how do i go about getting avisynth and then join the avi's
cheers
chris -
http://forum.vcdhelp.com/userguides/99389.php#cut_join
Use this guide to find the download site and install AviSynth.
Put this script into a wordpad or notepad document. Change the names of the files and their paths to your files and paths. Name the word pad file with a .avs extension.AVISource("d:capcap1.avi")+AVISource("d:capcap2.av i")
Once you have AviSynth installed and in your registry, launch Virtual and load the .avs file as you would a normal video. Once the file is loaded same the VDub file as an .avi file.Hello.
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
audio video mismatch
By sumeshkri in forum Software PlayingReplies: 1Last Post: 31st Dec 2007, 11:00 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 10:23
