Hi,
I seem to be only getting right channel sound when capturing in virtual dub. Whenever I enter my tv application (wintv 2000) i get sound from both left and right channels just fine. I'm using a hauppauge wintv pci-fm under windows xp. Thanks in advance.
Results 1 to 9 of 9
Did you configure VDub to capture in stereo? You know, in capture mode, select Audio-->Compression-->your favorite stereo setting?
Hello. -
Yeah. Load your video into Gold Wave, then see if both channels have audio. If you are missing a channel, copy the present audio channel, then mix it to the missing audio's channel. Save, then mux it with the original video with TMPGEnc. Good enough?
Hello. -
also try double clicking your audio icon bottom right task bar. check the recording options (properties) and make sure your BALANCE slider from the LINE IN or AUX or whatever you record from is centered.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
No Sound With Dazzle DVC100 using Virtual Dub
By kpoman in forum Capturing and VCRReplies: 3Last Post: 3rd Nov 2009, 09:35 -
DVD missing left channel...
By xichael in forum DVD RippingReplies: 2Last Post: 31st Dec 2008, 17:13 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 01:45 -
My VCR's Left Channel Died
By moviebuff2 in forum Newbie / General discussionsReplies: 17Last Post: 29th Jun 2007, 12:24
