thanks in advance, try to make a VCD out of an rm file.
I've never used it, but there's a program called tinra that can convert from rm to avi. From there you could encode to VCD format.
Tinra GUI is under "Other video encoders/converters" in the tools section of this site.
Let us know if it works.
cheers,
mcdruid. -
there is another way to convert .rm to .avi
goto:
1. control panel folder
2. system properties
3.performance tab and click the graphics button
4.turn hardware acceleration off
use a program like hypercam or any other screen capture software and capture your .rm while it's playing
then after just encode to mpeg with TMPEnc/whatever mpeg encoder you like and your done
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
How to convert MPEG-4 into MPEG-2 with a Mac
By VidHunter in forum MacReplies: 12Last Post: 29th Oct 2007, 01:23 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36
