I went to download the new version of TMPGenc today and again I see that they also have VFAPI plugin for download. I never was very clear on what VFAPI is and if I need it. The site just seems to assume that you would know.
I've been using TMPGenc for a while now and I have no idea if I ever installed VFAPI or not.
I really try to read before I post a question here. If the answer to my question is right there on that site and I just missed it please show me so I will know to look closer next time.
VFAPI as a standalone app enables you to make small 'fake avi' files from things like DVD2AVI .d2v files. These are a bit like signposts which help an app that can open avi files to open the other file format.
I believe the plugin for TMPGEnc just enables it to handle these sorts of files.
If you haven't had the problem of not being able to open something that you wanted to in TMPGEnc, then you probably don't need the plugin!
(others here will have a much deeper knowledge of this than me by-the-way, and if you're lucky someone else might answer your question better!)
cheers,
mcdruid -
TMPGEncOriginally Posted by presto
Option > Environment setting > VFPI Plug-in
If you done have it, you soon will need it
Download the plug-in, and and extract to your TMPGEnc folder, double click the "TMPGEncVFP_Install.bat" to install.
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
VFAPI Reader Batch convert?
By Totta in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 11:44 -
VFAPI and Windows 7 64 Bit
By JekhoOne in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 13:56 -
VFAPI aspect ratio change
By Weapon-X in forum EditingReplies: 1Last Post: 5th Mar 2008, 15:28
