Hi.
I'm wanting to know is recording VHS or TV Footage better in Quality using a DVD Home Recorder(panasonic DVD-DMR E20) vs Capturing and editing into a descent computer with a BTchipset or better capture card?
Thanks in advance I hope i'm in the right forum i'm sorry if i'm not.
TurboRunner 8)
The current model is the E30,
I can tell you that in highest resolution mode, image quality over analogue is stellar on the E30. And it's easy as pie.
OTOH, with a good capture system you will have more flexibility in terms of editing, etc. But with the E30, you won't suffer from dropped frames or audio sync issues, which some of the capture solutions may suffer from. -
I would go with the panasonic dmr. You won't get any fancy menus or anything but it sure beats spending a million hours on a computer to capture edit etc.. and the video and audio is the most important thing anyway and the panasonic is flawless when transfering video and audio. And you will get a higher playback rate on other dvd players .than if you used a computer dvd burner.
Help with Panasonic DMR-E80HS ... need to save home videos.
By Hollywood_12 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Dec 2011, 23:36 -
Panasonic DVD Recorder (DMR E75V) security dvd player restrictions
By paulmy in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2011, 13:43 -
Questions about Blu-ray recorders and Panasonic DIGA DMR-BW830 too
By KingKRool2002 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Jun 2009, 08:00 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 12:37 -
Pioneer and Panasonic DVD Recorders w/HD?
By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 15Last Post: 16th Dec 2007, 02:48
