I want to be able to capture large, high quality still frames from my tv and other video sources and convert them into jpg pics. Will a good video card be able to accomplish this task, or is there a different device for this kind of thing?
everything you need to know on this subject, as well as products also can be found here : http://www.pinnaclevision.co.uk/video.htm
or here
http://www.cs.columbia.edu/~hgs/rtp/frame.html
or check out the matrox rtx10 which has great still frame capture http://www.matrox.com/video/products/rtx10/capture.cfm
Can I get better quality captures?
By Aquamarine in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Jan 2012, 17:03 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 06:30
