Question might be kinda lame, but Ive been using the Verbatim DVD-R media and it has been working great without a hitch. But I recently got some Ritek $1.35 a disc deal and it seems my burner has been acting up in a way by giving me "power calibration errors and unexpected exception errors with Nero. I was just wondering if there is a possibility that by using cheaper media, it can in some way shape or form damage the burner, i think it may be farfetched, but im a newb to the DVD burning and Im just trying to break down whether its the burner, media, or software on this one. And if anybody else out there ever got any "power calibration errors" by using cheaper discs. THANKS!
Hi,
Same thing happened to me. I bought a 100pack ProDisk dvd-r ($1.49 each) and suddenly I get recording error messages.
I'm using Win2000 Pro SP3. I changed the IDE ATA/ ATAPI Controller Transfer mode setting for both primary and secondary IDE channel from "PIO only" to " DMA ". The error messages disappeared. But the burned DVD can play well in only one player. The DVD recorder itself ,Pioneer A04, cannot play the media. -
I found a solution to recording and playback problems using cheap media.
-Disable antivirus programs
-IDE ATA/ATAPI controller set to DMA
-Create a master copy on branded high quality DVD-RW disks
-Use disk to disk method to transfer data to Cheap DVD-r media.(it's better to use only one DVD drive for both source and destination drive. Use a fast drive for temp files.
-Set write speed to 1x and set Data and Audio Read Speed to 1x
Looking for some cheap Dual Layer Bluray media (BD-R DL) ..
By ahmadka in forum MediaReplies: 0Last Post: 26th Mar 2011, 23:07 -
WD TV Media Player Thumbnail issue
By dudeman316 in forum DVB / IPTVReplies: 2Last Post: 14th May 2009, 07:57 -
Windows Media Encoder installation issue
By George2 in forum Newbie / General discussionsReplies: 16Last Post: 11th May 2009, 17:43 -
What drive(s) CAN reliably burn cheap 8x DL media?
By miamicanes in forum DVD & Blu-ray WritersReplies: 20Last Post: 16th Feb 2008, 20:09 -
Sony Handycam DVD305 Media Conversion Issue - Please Help
By camp14 in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2007, 09:16
