Hello, I'm new to this forum but figured I'd ask. I've been around encoding mpeg2 transport streams for a few years but new to dvd burning. Is there a relatively cheap authoring software out there that will let me burn an mpeg2 video file muxed with an 2 channel split ac3 audio file?
Basically the encoder I use muxes the 2 files together giving me a .ts. I can demux them hence creating an mtv video file and ac3 audio but can't seem to find an authoring program to handle the audio.
Any thoughts would be appreciated![]()
Spruceup supports ac3 but it is discontinued but you can find a demo in our tools section.
i use a lot of transport mpeg - which is used for HD mpeg servers as well as sat feeds..
transport stream is not supported on dvd's directly .. but if you can de-mux them (there is are only few programs (software that is -- lots of hardware sollutions) that can demux a transport stream correctly and really only 1 REAL good muxer (http://www.lilapple.com/ Manzanita) you can as Baldrick says use Spruce-up , also Spruce Maestro , Pinnacle Impression DVD-Pro (the cheapest solution which supports ac3 5:1 i think) and Sonic Scenarist all support ac3 5:1 audio.
How do I play h264 transport stream (.ts) with AC3 audio on an Xbox 360?
By bubbrubb in forum Video ConversionReplies: 4Last Post: 12th Feb 2011, 15:02 -
no audio from transport/program stream file when i try to encode
By uptonm in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2010, 10:41 -
MPEG-2 transport stream... how to mux audio/video?
By Navstar in forum ffmpegX general discussionReplies: 1Last Post: 19th Feb 2010, 17:22 -
multiple audio tracks in transport stream
By levide in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 12:58 -
Extract problem dolby audio from transport stream
By DVWannaB in forum Video ConversionReplies: 7Last Post: 17th Aug 2007, 22:35
