I am trying to convert a divx movie I downloaded that is 699MB using DVD2SVCD. I selected avi as input file, but when I try and open the file under the convert tab I get an error message saying "You are using the wrong version of dvd2avi please download the correct version." Does anybody know how I can fix this? Thank you
Results 1 to 11 of 11
Here's an idea, it seems to want you download a correct version, well, download the correct version!
"We who are truly brave will never live in fear"
7 Time WWE Champion, The Rock -
I downloaded the latest version from the website. Can it be that I have to install the Nimo codec pak?
uninstall then reinstall dvd2svcd. you must use the programs that come with dvd2svcd becaused they have been tweaked by the maker of dvd2svcd to run with his program.
Where I walk, I walk alone. Where I fight, I fight alone. -
I have tried to uninstall and reinstall and the same thing happens. Are you sure I don't need to intall the codecs? Thanks again
If you cannot use DVD2SVCD why don't you try something else like TMPGEnc or CCE. Sorry I don't know about DVD2SVCD so can't help you much.
Stop Bumping the messages every minuit or nobody will help youOriginally Posted by harris5108
dv to divx problem
By anajat in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 19:27 -
Problem with divx container
By kyrcy in forum Video ConversionReplies: 6Last Post: 30th Jan 2009, 18:16 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 05:15
