im using this http://www.vcdhelp.com/sefy/?id=ClassicalGuide.html but how do i do this ------->In Order for TMPGEnc to recognise D2V files, you MUST have the VFAPI and the DVD2AVI.VFP file located where the TMPGEnc.EXE file is! it will NOT work any other way! It is also sometimes helps to use the Forced Film option in DVD2AVI, but only if you are still unable to open the D2V files with TMPGEnc. (suggsted by msfox)
I'm not sure if that plugin dvd2avi.vfp has to be in the same folder with TMPGenc.exe. But mine has it in different folder, dvd2avi.vfp in DVD2AVI folder and TMPGEnc.vfp in TMPGenc Plus folder. And so far I don't have any problems for TMPGEnc to recongnize my d2v file.
this is what i get
[img]C:\Documents and Settings\walser\My Documents\My Pictures\TMPGEnc problem.bmp[/img]
how do i upload an imige? -
http://www.vcdhelp.com/forum/faq.php#24Originally Posted by AMD1800As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 15:56 -
Question about extra (mystery) chains when ripping DVD with FairUseWizard
By jimdagys in forum DVD RippingReplies: 6Last Post: 28th Dec 2010, 18:26 -
DVD Ripping and conveting to AVI question
By undyingforce in forum DVD RippingReplies: 4Last Post: 24th Apr 2010, 13:05 -
ripping a dvd to mkv h264 filesize question
By stackner in forum DVD RippingReplies: 5Last Post: 16th Jan 2009, 18:13 -
DVD Ripping then Convert Question
By frodamob in forum DVD RippingReplies: 4Last Post: 23rd Dec 2008, 23:09
