Hi all, i just got a firewire card, it some brand i never heard of but it uses a TI chipset which is why i got it cause i heard they were pretty good and i got a good price for it. I got it mostly for catpure with my DV cam, thing is when i installed it, it detected fine by Windows XP, but i has a description saying "1394 Net adapter" but in another part its labeled as "TI OCHI compliant IEEE host controller" i want to know if this should work fine with my DV cam or not, i cant test it right now cause i lent it to my brother in law,(its a Panasonic btw) Thanks.
it would be more informative if you just test it with your dv cam after getting it back from your Bro-in-Law
...should work. The card being registered as a 1394 Net adapter and OHCI compliant controller...is normal.
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 20:45 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 17:22 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 16:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 09:20
