Ok, when i try converting my .avi file(maybe a divx file) it goes off sync with the video, so i tried using vdub to extract the audio, but vdub won't let me do it, it says: the requested audio compression is not compatible with the input format. Check that the sampling rate and channel count match those of the requested format.
ok, what does that mean? what do i do?
At a guess I would say the Divx contains either VBR MP3 audio or AC3 audio streams. In vdub, use audio-direct stream copy, file-save as wav and then use either BeSweet or HeadAch3e to convert to stereo wav. Search the forums or HowTo's for more info.
VirtualDub won't open divx movie
By shmish in forum Video ConversionReplies: 9Last Post: 15th Mar 2010, 07:54 -
VOB file won't process in VDub
By CursedLemon in forum DVD RippingReplies: 3Last Post: 17th Sep 2009, 16:35 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 21st Aug 2007, 23:38
