Hello again, just a few words to tell you people that i just succesfully copy a dvd into a VCD.
Using my stand alone Clairtone DVD player pluged to an ATI Wonder TV capture card i recorded the dvd into a AVI file, later on i re-encoded and compress it with TMPGEnc to finally burn my VCD with Nero, at this point i didn't wanna try making chapters or anything like that cuz was my first time![]()
In conclussion it works fine and i tryed it on with my DVD player, the Panasonic RV-32 and a Pioneer wich a don't remember the model. So no need to have a DVD-Rom in your computer to do this job. Hope that helps.
I did that before I got an old 10x dvd rom (for free)and I gotta tell you if I had known the movies looked so much better when you rip them from a rom than when you capture them I would have bought a rom years ago .
And Im not sure about your system but mine will rip dvds in the same time that it takes to watch a movie , well actually itakes about 3 hours for an hour and a half movie but thats converting the vob to svcd and the picture is flawless. So if you havent ripped from a rom or seen a rip from a rom the quality is light years above capturing it . I have the same cap card as you so I know the quality it produces.
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
is there a simple way to convert an avi to vcd?
By lks9042 in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2009, 03:00 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Simple VCD/SCD creation with freeware.
By bigstusexy in forum Authoring (VCD/SVCD)Replies: 11Last Post: 3rd Dec 2007, 23:24 -
Vcd + data simple project
By wilsoncortez in forum Authoring (VCD/SVCD)Replies: 13Last Post: 29th Jun 2007, 23:06
