Is it possible to rip a regular store bought DVD to an image file (.bin) using any imaging software?
If so; will it be able to be burned to a CDr with lets say nero, as long as i include a proper .cue file to tell the system where to look for the .bin??
Thnx in advance!
my nero won't burn the bin but it does recognize the cue file, but yes what you speak of can be done
I know this probably isn't the right place to ask this but with the information from my last post, it fits.
How can i convert a .bin to a format that can be burned by nero or EZCD 5 and what format should i convert them to?
Next question: If I can convert the .bin to a different format, how can I tell what the original format was before it was imaged? -
Theoretically, yes, this could work, IF your DVD is very short or you want to use 6 or more CD's.
Converting a BIN involves first extracting the MPG file from it, you might as well skip the bin step.
DVD conversion is covered in great detail in the guides to the left. -
I am currently learning how to all this thnx to this site and these forums. That will work great for the future of ripping but do you have any suggestions on what do do with the one(.bin) i got. It also seems that every time I attempt to obtain a new movie they are always in .bin...
Any suggestions at this time would be greatly appreciated cause im lost -
You did not mention DL'd bins, from your question I assumed you were talking about a rip you had made. A DL'd bin is already encoded, just burn it, Use NERO and select the CUE file.
resolution (?) image squashing problem with DVD rip
By suburban100 in forum Authoring (DVD)Replies: 9Last Post: 13th Sep 2011, 20:24 -
How to rip DVD's: Image File or VIDEO_TS-Folder
By flashandpan007 in forum DVD RippingReplies: 3Last Post: 9th Feb 2010, 11:08 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
