I have just purchased the WinTV go card which is very goods for the price. I have tried using various capture programs and the one i found had the most watchable picture for VCD's is WinDVR. The only problem is that after varying lengths of encoding the computer freezes whilst still playing audio. I have not had this problem with any other capture program. Could anyone please help me as i am very pleased with the encoding quality.
My specs are:
P4 2.20ghz - 512MB ram - 120gb hd - GeForce2
Hi
What version of winDVR is it??
I know when I installed the trial version of WinDVR 2 the first time it kept crashing. Try a reinstall of the program.
What other capture programs have u installed??
Cheers
Fozzee -
It is version 1.8. I am also using Wincoder 1.8 which uses the same encoding engine and I have the same problem. I have had no problems with programs such as PowerVCR II, NanoDVR, but i just don't like the quality of output. I have used a trial version of 2.0 but being that capturing stops after 9mins of so, it is hard to judge if there is still a problem because it normally crashes after then.
Computer Locks Up, Freezes Completely After Being On About an Hour
By p_l in forum ComputerReplies: 33Last Post: 28th May 2012, 16:26 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 00:35 -
ImTOO - COMPUTER FREEZES
By orpey in forum DVD RippingReplies: 7Last Post: 11th Oct 2007, 05:57 -
computer freezes, won't allow WinXP install
By iThinkYouBrokeIt in forum ComputerReplies: 15Last Post: 13th Aug 2007, 18:07 -
computer freezes when encoding
By persiani in forum Authoring (DVD)Replies: 3Last Post: 17th Jun 2007, 18:23
