  1. I was wondering if Panasonic Mpeg encoder was worth the money because I need to convert .avi into an mpeg because tmpgenc dosent work on my computer for some reason or unless somebody can tell me how to burn .avi's
    May 2001
    London, UK - Bonn, Germany
    You should download the trial version to see if the Panasonic MPEG Encoder can encode your clips. Usually TMPGEnc will encode more than the Panasonic can, so maybe the fault lies somewhere else.
  3. I downloaded the trial it worked great.
  4. that F*** tpm thing NEVER worked for me ..
    Panasonic RULES!! ...
    'nuff said!
