I downloaded the sweetest thing in divx format that is 699mb. How can I burn it so I can watch it on my stand alone? Thanks to all.
If your standalone supports SVCD the easy way is to use dvd2svcd (look under tools).
Just select avi as input, let it run for xx hours and you will have two bin files ready for burning.
If your stand alone "only" supports VCD try the Tmpegenc guide found under guides - it works as well.Best regards
Jens Gervil
Virtualdub thing contains a virus
By KneeRow in forum Video ConversionReplies: 35Last Post: 24th Oct 2025, 15:47 -
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 03:53 -
no such thing as an asf plugin?
By uglijimus in forum Video ConversionReplies: 10Last Post: 10th Oct 2009, 22:56 -
Why is there no such thing as 60FPS above 320x240?
By Syclone0044 in forum Newbie / General discussionsReplies: 29Last Post: 28th Sep 2009, 14:22 -
The One Thing That Can Save HD DVD
By cracula in forum DVD & Blu-ray PlayersReplies: 12Last Post: 19th Feb 2008, 12:52
