Just wondered cause an extra cpu doesnt half speed up the encoding process.
How are you feeding it your video stream? If you are frameserving, the frameserver is NOT dual processor capable and this is your bottleneck.
yeh im frame serving.....i guess theres no way around this? well no way that would make the process any quicker
You can run two processes in parallel since one CPU would be idle ( assuming you are not IO bound to begin with ).
I'm new to CCE, but testing it out the other day had both my CPU's around 80-85% (DVD2AVI->AVISYNTH->CCE). A single pass on a 2 hr movie took just over 1 hour if I remember correctly. Speed was around 1.8
Thats damn quick enemy! What cpus do u have? mine only seem to run at 60 odd % capacity and a two hour movie takes about two hours......im using vfapi oposed to avisynth wonder if that makes a difference?
My main system is 2x2100 MP's. Avisynth definately makes a difference, as it probably took twice as long with VFAPI.
One LCD is flickering on a dual monitors setup
By tigerb in forum Newbie / General discussionsReplies: 4Last Post: 25th Jan 2009, 03:19 -
premiere pro+mainconcept hd: best hardware setup (hdraid, cpu, ram)?
By razzta2001 in forum EditingReplies: 9Last Post: 8th Oct 2008, 07:54 -
How to create a dual monitor setup?
By Denvers Dawgs in forum ComputerReplies: 20Last Post: 1st Mar 2008, 21:00 -
what dual layer dvds should I be using with the following setup?
By transient_today in forum MacReplies: 1Last Post: 22nd Jul 2007, 15:05
