  1. Can anyone point in the direction of a site that lists the size of movies and whether they are dual layer or single layer
    I know one exists as I have seen it on another forum but cannot remember which one.
    Someone has that database somewhere......
  2. Thanks for the reply, but I think you misunderstood.
    Someone somewhere has listed out all the films and their sizes so you know whwther your dealing with a single or dual layer.
  3. did you check that site i just posted?...if you look up any dvd title on there it tells you if it is single or dual layer..if you're looking to find out exactly how many gigs a certain title is then sorry i can't help you..but if you want to just know what is single or dual layer then check that site..it even tells you if it is single or double-sided.
