Using Adobe Premire i have found that the extracted audio file seems to remain at 30fps i need to change the rate to 29.97fps. I have stretched the audio file to fit the length of the converted avi file. The audio is in sync for about two minutes, enough to think the audio stretch worked, but as it continues to play it gradually goes more and more out of sync.
Is it possible that the frame rate could be the problem. I have even tried to fix the mpeg in MPEG-Corrector didn't work. I also noticed that after the fix when I try to demultiplex it I get a padding stream instead of the video and audio files. I save this padding stream and I get a file called 0BxE.dat What is this?
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 11:27 -
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 20:58 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 03:32 -
how do i know if Nero is changing my audio bit rate?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 19th Nov 2008, 16:49
