Hi, trying to help a M8 with there player. All NTSC films showing in black and White, anyone know how to swith from PAL to NTSC and Vice versa on this player.
Thanks in advance.
Gary
I've never seen the player you mention, still most of the times you change that setting on the Tv
here's the hack for your playerTo convert this player to Multi-Region
1. Power on your machine
2. Press the Stop, Open/Close, Skip Forward and Skip Backward buttons on your player simultaneously and hold down for 3 seconds
3. A hidden menu should appear. Release the Stop, Open/Close, Skip Forward and Skip Backward buttons on your player
4. Select Region Number from the hidden menu and choose the Free option. DO NOT make any selections from the Initialised Type menu, this can leave your machine inoperable. If you do by accident, go back to this menu and select option 1.
5. Exit the menu
To convert this player to Multi-Region if the above doesn't work
2. Press the Stop, Open/Close and Skip Forward buttons on your player simultaneously and hold down for 3 seconds
3. A hidden menu should appear. Release the Stop, Open/Close and Skip Forward buttons on your player
4. Select Region Code from the hidden menu and choose the Free option. DO NOT make any selections from the Initialised Type menu, this can leave your machine inoperable. If you do by accident, go back to this menu and select option 1.
5. Exit the menu
6. Your player should now power itself off
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
