just got my self a dvd burn pioneer drv-104, and am wanting to watch all my .avi on my computer on dvd, not entierly sure what to do, woundering what the best method is 4 the process, been through all the help pages and that, but want to know what other people do, i know i can convert the file to mpg1 (vcd) but that gives crap quality and not sure if svcd is supported. i know there is an option to convert to dvd but that said it would take 24 hors but then that crashed so now im waiting to c what people tell me, cheers guys, n e help would be much appriciated.
I assume you are talking about using TMPGEnc to convert to MPEG. Encoding to DVD does take a while; using CBR at full DVD resolution will probaby take over 4 or 5 times the original AVI clip duration at your processor speed. Doing 2-pass VBR will take even longer.
Just let it run overnite, and select the shutdown when finished option and it will turn your PC off when it's done.
Best/Fastest .avi to dvd convertor/burner?
By xxnonamexx in forum Video ConversionReplies: 2Last Post: 24th May 2010, 20:53 -
Newbie HELP!! DVD to AVI
By Bolisk in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2010, 00:36 -
Newbie converting DVD to AVI
By nuggett_aus in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 06:31 -
Newbie Help - Very Large AVI file to DVD
By Lebowski25 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 22:42 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 09:48
