I have a DAZZLE DVC II PCI card. When I capture from a VHS tape in Video CD format and burn the CD, the picture is Choppy and sometimes no picture at all only audio. If I use a Xing mpeg encoder to encode before writing then the CD plays well.
Is it necessary to encode the clip( I feel that the clip should not be encoded because we are capturing in Vedio CD format with all parameters fixed)
Is it the problem of the computer hardware or is it the problem of the DAZZLE card.
Can any body answer this question.
Results 1 to 1 of 1
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 03:08 -
how to use ffdshow to encode captured video into h264 in directhow
By vrparekh@gmail.com in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Apr 2012, 12:08 -
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 10:31 -
Good bitrate to encode a DV file captured from a VHS tape to h264 mp4?
By incubuscsg in forum Video ConversionReplies: 2Last Post: 4th Nov 2010, 17:30 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26
