I need help. Seriously. I can't get my Asus V6600 Deluxe card capturing in WinXP. I've read something about the TechnoGarb drivers, but I can't find them anywhere.. So could someone please explain to me how can I get my card capturing in XP ? What do I need and where could I find them? I tried capturing with AsusVCR v2.0, but it just freezes over. It would be a lot easier, if I could capture in XP, because I really don't like this two operating system thingy (In 98SE capturing is no problem). And XP is more stable on video editing. Help me please.
Results 1 to 10 of 10
Seriously.. I need help and I think there are others too in this forum who need help also. I tried to find those technogarb drivers at www.maxreboot.com/technograb/ but there wasn't any pages..
AMD Athlon Thunderbird 1200Mhz
ABIT KT7A-100 Raid
128MB Mushkin SDRAM (155Mhz)
82.0GB Ibm Deskstar 120GXP (7200RPM)
Asus V6600 Deluxe (Geforce 256, Video-In/Out)
LG 16x/10x/40x CD-RW Drive -
tuomol,
I had a little time to kill so I did some research on that card. From what I can gather ASUS has dropped all support for it. The last driver update posted was way back on April 14th, 2000. My only suggestion would be to head over to nvidia.com and download the latest reference driver.
http://www.nvidia.com/view.asp?IO=winxp-2k_30.82
I don't know if will work but it's worth a try. -
I've tried the nVidia refrence drivers, but VirtualDub or AsusVCR doesn't capture anything with it. It says something like can't connect to the wdm device or something.. TechnoGarb was the best place to find Asus capture drivers and info about capturing with asus cards. I just want to know where I can find those drivers and that info..
ABIT KT7A-100 Raid
You need to download the WDM capture drivers in order for capture to work. You can find them here: http://www.nvidia.com/view.asp?IO=pc_winxp-2k_30.82
Those personal cinema drivers don't work either. I've heard something about the hacked TechnoGrab wdm/display drivers for asus cards that work on XP. Doesn't anyone know where could I find those drivers?
ABIT KT7A-100 Raid
tuomol,
I tried to point out in my earlier post, your card is no longer supported by the manufacturer. Any hacked driver you install in XP is more than likely to cause you more trouble than it’s worth. As to this site you’re mentioning I’ve never heard of it. You might try looking over at DriversGuide.com
http://www.driversguide.com
2 words to remember: drivers, all. -
tuomol,
I did a little more digging and ASUS does have a beta version of the driver you've been looking for. Check this out and see if it helps.
http://download.asus.com.tw/mm_dl_menu.asp?Status=101&l1=2&l2=2&l3=3&mid=4
I'm outta here for the night........
I tried those drivers and when I try to capture video, the picture just freezes and then when I stop the capturing process it unfreezes.. Isn't there anybody who knows something about these asus cards and capturing video with them in win xp ?
ABIT KT7A-100 Raid
I have the same problem. I tried Asus's drivers, and nvidia's drivers... nothing lets me capture.
Has anyone found a solution to this yet?
No dvb-s signal from satellite and Asus My cinema es3-110 card
By mammo1789 in forum DVB / IPTVReplies: 4Last Post: 28th Dec 2011, 18:13 -
Using ASUS ENGTX460 DirectCU Graphics Card To Convert .mts Files?
By JohnnyGalaga in forum Video ConversionReplies: 30Last Post: 15th Jan 2011, 23:22 -
Any Kworld Capture Card Users: Help!
By rind1984 in forum Capturing and VCRReplies: 5Last Post: 3rd May 2009, 22:50 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 07:55 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
