Hi, I am new to this and do not understand some of the terminology in the help files.
Simply I want to convert this file (currently 198 mins) to something smaller so that I can use TMPGEnc to burn VCD. When I start the TMPGENC it tells me that it is to long for the medium it is intended for (80cdr), I have tried to set a start fram and an end frame but it freezes the pc about 5% in.
Can you please suggest an easy ans simple way for me to do this.
Nicola J...
You don’t need to convert it to anything smaller for TMPGEnc, no matter what you did TMPGEnc will make a VCD mpeg 1.
Apart from cutting out any trailers, or credits, you cannot fit 198 minuets onto a 80 minute CD without loosing a great deal of quality, AND your DVD player may not play it.
If TMPGEnc is freezing at 5%, you may have junk frames in the original, if that is an AVI.. Load it into Vdub and scan for junk frames, then SAVE AVI with video/audio > direct stream copy
Load a VCD template in TMPGEnc (PAL or NTSC) and click start, later use Merge&Cut to split the file into 2 mpeg 1 for use on "2 CDR"
Reducing the size of an avi file with Vegas 9.0
By solarblast in forum Video ConversionReplies: 10Last Post: 3rd Sep 2011, 23:01 -
Reducing video file size
By black5 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jul 2010, 18:09 -
Limitingand reducing out file size
By TJF in forum Video ConversionReplies: 6Last Post: 7th Feb 2010, 10:25 -
Reducing AVI/DivX file sizes
By webstar in forum ffmpegX general discussionReplies: 5Last Post: 17th Jul 2007, 10:52 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 05:41
