    Italy
    well... the topic says it
    if i install the codec pointing dvdx directory and then try to encode, i get an error. does it work for you?
  2. hi,
    I've used the PanEnc plugin with DVDx1.8 before with no problems.
    Once you've installed the plugin, do you have a file in your DVDx install directory, with a .prm extension? I think you should do if it's worked right.
    You could try renaming the panasonic plugin file to a .prm if you need to.
    From the DVDx2.0 readme file:
    -To install an encoder for Premiere , Run the plugin setup and Select
    the directory where DVDx files have been copied.
    If you update a plugin, to avoid a conflict, you should remove
    the old windows registry database entry where plugin setting are storred :
    HKEY_CURRENT_USER\Software\DVDx\Output_Setting\Plu gSetting\a_plugin.prm
    where a_plugin.prm is the old plugin name.
    ' hope this helps,
    mcdruid
