I'm looking for others with the SD3750 player. There seems a lack of info on the XVCD format, which interest me since the VCDs I've seen are of poor quality. This player does not support SVCD!
People have complained about finding discs that work...I've used e3 works (colored) discs and it worked fine for VCDs.
Any tips for burning killer XVCDs for the SD3750??!
Results 1 to 1 of 1
I support: DVD, XVCD
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57 -
Problem With my Toshiba HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2008, 13:49 -
Has Anybody Emailed Toshiba ??
By ofield1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Feb 2008, 08:31 -
Toshiba SD-43HK.
By jabbashouse in forum DVD & Blu-ray PlayersReplies: 5Last Post: 31st Jan 2008, 11:07
