Downloaded movies from the internet... transfered movies to VCD with TPEG and nero...
during playback, more often than not towards the second half of the disc.. everything freezes.....once in awhile for probably 10 seconds.
Ideas?![]()
The same thing happened to me on a stand alone DVD player and it got better after I cleaned the lens, you can get a lens cleaner at any electronic store.
What is your player? With Philips DVD players a firmware update helps.
You may or may not fix this problem, use the best quality disks like Maxell or TDK and use a VCD template with TMPGEncOriginally Posted by like2gamble
On disk 2 ? or do you have 1 movie on 1 disk joined ?second half of the disc
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 16:23 -
program freeze
By mulgui in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2009, 22:03 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 17:15 -
Svcd2dvd Freeze's
By gazinc in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Apr 2008, 14:00 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 05:12
