I have a panasonic rv32 and I need to disable macrovision. A friend has the service disc and codes for an rv31. Will it work? I'm loathe to just put the disc in and enter the codes in case it screws the machine up. thanks.
jack99:
many of the tricks aplied to RV31 are also valid for RV32. I advise you to try the tricks you have on your RV32.
In case you make a wrong move try reseting your player with the RESET SWITCH trick recently posted in the PANASONIC RV32 hack page (on VCDHELP.com). The macrovision hack wasn't discovered yet, but I think the answer is on those service codes you got.
Finally, I would really like if you could pass me the files of your service disk to: molinas@telesurf.com.py.
Thanks a lot!
FER-PY :
Pioneer dvr-450h data service disc
By A/VPHREAK in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Jul 2010, 17:14 -
Cannot start a service
By jollyjohn in forum ComputerReplies: 4Last Post: 5th Nov 2008, 06:03 -
Need Capture service
By kevinhanson in forum Capturing and VCRReplies: 8Last Post: 28th May 2008, 17:38 -
Need a reminder service for PC
By ViRaL1 in forum ComputerReplies: 1Last Post: 27th Dec 2007, 18:58 -
service mode?
By iThinkYouBrokeIt in forum DVB / IPTVReplies: 4Last Post: 28th Oct 2007, 00:35
