Hi all.
I just recorded a 5 minute video with WinDVR 2.0 using the PAL 1/2 DVD HI-Q profile and now i have a problem.
When i try to open the file with the following prog i get the following message:
Virtual dub - MPEG import filter: pack synchronization error;
TMPGenc - can not open or unsupported;
Windows media player - Works fine.
CAn anyone tell me what to do so i can open the video file on Virtual Dub and TMPG Encoder.
Thanks all
PS: Keep in mind that im news in this things.
Hi
I only have the trial version but.....
Just tried it and had the same problem in 1/2 DVD. But full DVD setting would open in TMPGEnc ...strange. I have PowerDVD and WinDVD4 installed so codecs shouldn't be a problem. I'll keep looking at it see if I can figure it out.
Do you have the full version of WinVCR2???
Cheers
Fozzee
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 14:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 17:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 16:34 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 19:01 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 11:39
