Hi,
Do you know if this player (SAMSUNG DVD V1000) supports PAL VCD's?
I know that it plays VCD's and SVCD's but I'm not sure if the PAL format for VCD's is supported.
Basically, I want to purchase some VCD's from several stores on the web. Mostly (if not them all) are in PAL format.
Check this site (they say that the VCDs are in PAL format) : www.allvcd.com
Of course I alreay called to Samsung customer support, they didn't know what a VCD is (even though the box of the DVD player says that it supports VCD's).
So, anyone out there that has purchased VCD's on the web and used them on this player?
Thanks for your time.
Results 1 to 1 of 1
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
Changing PAL to NTSC on a Samsung DVD-HR753
By sni6ero in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Jul 2008, 11:34 -
PAL Disc on Toshiba D-R400 and Samsung LNT5265F
By super_pipo in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Jan 2008, 11:40 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
