can anyone help me with a SM Supervision 2500. my friend has got one, and just about every VCD plays out of sync, i have even re-encoded one splitting audio/video to no avail.
any help would be appreciated.![]()
they work on everybody elses DVD player, i was wondering if there was anything he can do to put it back in sync. i have a philips 751, and i just press pause and it does the trick, but not on his! he just wants to see if there is anything to be done so he doesn't have to buy a new one!
friend of mine had the same problem, good idea is to create two seperate streams, the mpg and say wav audio and then using something like Nero Wave Editor. open the audio and chop a bit off the start experiment with say 100th of a second etc till you get the right one, then mult9iplex files together, should be out of sync on pc but in sync on player
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
