WHAT are the top 10 CD's for burning Music?? What about for video?? what about if you want to do both?? Because i have herd if you want the best quality sound in your car ..it has to be a cdr that is only for music ..is that true?? **if you dont have 10 that is OKAY LOL!
I always thought Memorex was the best but when i compared it to TDK last night..MemoreXhad this faint chirp in the backgroud that TDK didnt>?? Whats that about?
I THOUGHT it was like this, but now i DONT KNOW??!!
Memorez
Vertabrium
TDK
Fuji
I know one thing for sure..SONY SUX!!! LOL
Results 1 to 13 of 13
FujiFilm always worked well for me. I've never gotten a memorex cd to work for me...they all crash my computer.
I abuse most of my cds and they are played where I work, which is a noisy factory. The cheapest ones are the best, in my case.
CDR's that use Taiyo Yuden dye. 50pk Fujifilm use this kind of dye, Kodak are also good.
My bet is TDK. I never had problems with any brand and for data I use the cheapest ones I find. I buy a pack of 25 CDs 0.35€ cents each ehehe
I never tried one of those Audio only CDs and the only rumour about them that i've heard is that the difference between them and the regular CDs consists on a porcelain layer to protect from scratches -
The Memorex CD's that I see in the store are sometimes cheap ones made in Taiwan or good ones that are Tayio Yudens made in Japan (same as Fuji). So if Memorex is on sale, then only buy it if it is made in Japan.Originally Posted by tgpo
The made in Taiwan Sony's suck, but if you can find a made in Japan Sony spindle, then they are probably Taiyo Yuden's and are quite good. I still see them around sometimes.Originally Posted by salkam
I always recommend the same 2. Verbatim and TDK. Both have served me well for data, music, VCD, ghost backup and pretty much everything. And the TDK are always on sale and have rebates
Kodak Ultima and Verbatim DataLife Plus.
Regards.Michael Tam
w: Morsels of Evidence -
Verbatim Datalife Plus (Dark Blue layer only)
All Taiyo yuden
- Fuji
- some Memorex with black plastic on top
- Sony
- some TDK (some TDK are CMC not Taiyo)
Can I suggest for worst as well
- Cheap Brand sell at Fry's (Top layer pill off in player)
- PNY (Top layer pill off too easy)
- Imaton
BTW I have used them all not just say for other post.
i have just orderd 20 CDRs to try ...
they r black insted of blue or silver , does any one know how r this kinda CDs the brand name is - MCD. -
I have one 16 pack of black cdr from Compusa. Most of them I use only for Audio CD. Why? "becuz it looks cool".
I don't think it will make much different thou. some said Black Layer will protect scartch better than others. Some also said it will last longer than other. I don't know and I don't see any different but one thing I know for sure it's more expensive than others
ok i c.
by the way i don't know where u'r from but here they don't cost much at all about 35 cents a disk .
an ordinary tdk or verbatim CDR .
and another thing they sure r fast up to X40 burning speed.
Review this system.... (top quality)
By Engineering in forum ComputerReplies: 79Last Post: 21st Dec 2009, 21:12 -
a top quality powerlevel website
By xgame in forum Off topicReplies: 0Last Post: 2nd Sep 2007, 22:13
