Hello everyone!
What program should I use to capture WITHOUT SYNC LOOSE (like Ulead MediaStudio)?! The problem to use MediaStudio is which I can't select any codec (function disabled, I don't know why)Mostly of my captures are from old VHS...
Please help me!
Thanks in advance
Results 1 to 9 of 9
You can capture with Virtual Dub and select Capture AVI-->Capture-->Settings-->Lock video stream to audio.
Hello. -
I forgot to mention... I want a program to keep the frame rate. I've tried to use VirtualDub, but I got a lot of frame drops :/
Is there another program which I can use with this options? -
Are you using this guide?http://forum.vcdhelp.com/userguides/89899.php
Hello. -
The question is not "Why". The question is "Why not"? You do want to capture without losing frames? If the answer is yes, this guide has the stuff you need. Want to give it a try?
Okay man, I'll try, but I think it'll not solve my problem...
Because mostly of my captures are from old VHS tapes and using the majority of the programs, the frame rate decrease a lot when I capture from my tapes :/ And I've tried with VirtualDub and don't got good results...
Btw, i'll try and thanks
Can't tell if it solves my problem....(I've got the same thing going kinda) I can't tell what I'm losing because it won't capture sound, no matter what I do
Any hints?
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 08:49 -
Best Capture Program???
By Dom_Sisko in forum Capturing and VCRReplies: 2Last Post: 11th May 2008, 21:49 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Screen Capture Program ?
By Endemoniada in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 14:45
