can anyone help, i have been using vitualdub, and would like to know how to use the SCAN VIDEO STREAM FOR ERRORS part of the program, i have loaded the file and scanned it, it tells me there are 3 frames that are unreadable, how do i find out what frames they are, how do i delete them, and what effect will it have on the finished film, will it jump if i remove a frame, or should i just leave it well alone???
thanks pete
Results 1 to 1 of 1
How to install VFW codec alone for VitualDub?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2008, 17:44 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
